Curiousity
Materials
- Jul 21, 2002
- 1
Can an extremely fast setting silicone be made for self-healing holes?
Let's say an aircraft at altitude (extremely low outside temp and high pressure differential) developed a hole. A layer of silicone under high pressure is inserted between an inner and outer skin. Could a silicone be made to seal the hole and set fast enough to keep the aircraft from decompressing?
