Simulate cooled block
feikebrouwer
1
I want to simulate a steel block with water-cooled holes. On top of the block is another steel block (374 deg Fahrenheit) that has to be cooled by water-cooled block.
How can I simulate the heat distribution (and change) in the water-cooled block with Solidworks? I tried, but can't find the solution.
Thanks a lot!
Feike
Floworks would also be an option.
"If you have an important point to make, don't try to be subtle or clever. Use a pile driver. Hit the point once. Then come back and hit it again. Then hit it a third time - a tremendous whack."
Winston Churchill
