A C5+ in itself is a little vague, are you going to consider it as pentane, hexane, higher? For dewpoint calculations, the heavy ends are all important, thus this is a major point. Plus, I have my doubts about lab analyses for accuracy of the heavy ends. I've rarely seen a lab analyses that when back calculated for the dew-point, the calculation matches the process stream it is coming off of (for example, if I'm taking a gas stream off a 2 phase separator at 500 psig and 60F, the lab analyses back calculated for the dew point is rarely match 60F. This is just because of the problems of measuring very low concentations of trace components and the calculation accuracies).
If you don't have access to a process simulator, this is a basic dewpoint calculation. Look in your engineering texts, the GPSA engineering data books also walk you through doing this.
