Pressure Vessel Study?
Mechanimal
42
I using comosworks 2008 and have in the past been able to use the pressure vessel study which allows stress linearization. But for some reason that study option is not coming up, only static analysis is. Usually I create one or two static analyses and then use the pressure study to sum the stresses and linearize them.
I have checked previous work I have done and can view and modify existing pressure vessel studies but can't create new ones. I am trying to analyze a flange, has anyone else had this issue?
