Flow Simulation-Inlet Error 1
cardiomed
50
Here is my final model, I need to run the flow inside. The inlet port is the tube/pipe tangent to the surface on the top (dome or semi-sphere)part and the outlet port is the pipe on the bottom, (the other small pipe normal on the top is the air-vent) we dont need it here.
SW keeps giving the error for my inlet selection and does not proceed the simulation,
Any help????
Flow rate:6.1 in^3/min
Temp: 98.8 F
The 'help' in SW says: create/define the lid for your ports to make it a closed system, and their sample image looks like mine, ..Also, in my model when I (swap and) define the outlet as the inlet FloXpress accepts it but again for the other port (new outlet or real inlet)I encounter the problem.
I am still not sure if you can open the files,
Yet, I didnt reach to the point where BCs. would be required (if there is any), the only entries I was prompted were pressure OR flow rate AND temp. Again, when I change defining the ports my new inlet is accepted only.
I had to get this project ready by yesterday:(
In my few tries at this I have made the caps bigger than the port they cover and with a surface at the very edge of the feature. This way I can select the surface in contact with the flowing fluid. The well-fitted plugs you have are good for engineering design, for for flow analysis they need to be bigger so you can select the other side.
"how it worked for me"
Hardie "Crashj" Johnson
SW 2010 SP 2.1
HP Pavillion Elite HPE
Also in working with your model it seems the fluid cannot get thru the filter . . .
SW 2010 SP 2.1
Thanks for your tries SnowCrash,
Yeeah, today I took off the filter and kept the rest as they were, then ran the simulation and it did work, SO,yes you are right, my filter is not good, I defined it as polyester and then MESHED it using the APPEARANCE feature to put holes in its body, which apparently didnt work,
I would appreciate it if some body gives a hint about how to make a 'filter' in SW,
cheers,
A couple of things to try:
I don't know if this is an artifact of the translation to parasolid, but there is a gap between your ventCAP and cap1_-_CBL parts. I had to close that before I could do anything with the model.
Make sure the computational domain includes the whole model. By default it was coming in at only covering a fraction of the assembly.
Set your filter to be porous (FloWorks>Insert>Porous Media). You'll have to figure out what specs to put in for just 'how' porous the material is.
By doing these three things I was able to make the model run. Attached is a quick picture of the flow lines generated - don't take it for anything other than example that the model can be made to work. I used your flow rate & temperatures, but I don't know the other important inputs - nor did I let the analysis run to completion.
 http://files.engineering.com/getfile.aspx?folder=f4e442b7-dd83-41bb-a760-9dc8d0992c95&file=pretty_flow_picture.pdf
And here are a couple of things:
Thank you for your try and hints.
I think the package (SW) I have does not carry the flow simulation or FloWorks feature, I am only using FlowXpress here which is unfortunately very basic, ..probably this feature did not install while setting the software or something. Or I might get it installed now if that's possible. FYI,it is a 2010 version, so it should be pretty powerful.
I tried it again now (on FloXpress)and it did accept the inlet, but then for the outlet it did not which is obviously b/c of the filter. Since I couldnt find the FlowWorks somewhere I wasnt able to set it as a porous material.
My goal at this point is setting the filter as a porous material which passes the fluid throu.
Ah, I think you're out of luck. I was assuming you were using FloWorks. I'm not familiar with FlowXpress, but I doubt it can handle porous materials.
None of the '*xpress' tools are 'pretty powerful' regardless of what version of SolidWorks it is for - they're all cut-down and quick setup versions of the full programs of the same name. They can do the very simple, and give you a taste for the abilities of the full versions.
I think you're going to have to ignore your filter (which likely makes your results meaningless) or pay for FloWorks or equivalent(not cheap).
SteveMartin,
Thanks for your help anyways,
