EntryLevelEIT
- Jun 24, 2010
- 42
Hey Gentlemen,
I'm reviewing a stair submittal sent by the fabricator. The top landing is anchored to a concrete wall by a kicker. My goal is to check the adequacy of the connection (in particular the bolts anchoring into the concrete). As you can see by the attached pic the bolts are not eccentric. An example in my book has a tension-shear interaction check, but the bolts are eccentric, and the centroid can easily be found. Does anyone have any examples or guidance for the senario I have here. Plz see both pics, help is much appreciated.
