Simulating Wind Tunnel Experiments- Test Facility nozzle and constant
FlyingGrimReaper
Aerospace
I am curious about what exactly the limits of Flow Simulation are for SolidWorks. I was working on a thesis (completed and cleared) which was to analyze a scramjet isolator scaled up for 10 and 100 times the cross section. The initial CFD analysis was to simulate M=1.8 airflow entering from a C-D (converging-diverging) nozzle into a scramjet isolator.
The overall CFD results matched the experiemnts however I was not getting the correct contour plots for the flow. In scramjet isolator operation, there is supposed to be a normal shock train which develops. (I posted link of what should be seen on page 252.)
Now the simulation had a constant exit pressure boundary condition. The experiment itself used a throttled valve to control the back pressure (i.e. increases the pressure values as it closes).
This comes to my question, is flow simulation capable of creating a boundary condition which can increase the pressure to a maximum at an inlet or exit for a time dependent simulation? This parameter is essential for simulating back pressure and creating the shock train. This should also be within the high Mach flow conditions for Flow Simulation.
You can create time-dependant boundary conditions. Not sure if that's what you're looking for, or if you're looking for a boundary that changes in response to some other variable in the study. I *think* that's possible too, but it's beyond the scope of what I know how to do.
Anyhow, to make the BC a function of time, click the Fx button next to where you would input a constant property value. You should get a 'dependency' window pop-up. At the top of the window will be a drop-down for Constant, F(time) - table, or Formula Definition. I'm not sure how to use 'Formula Definition' (never had to), but entering a table of time and BC values is easy enough. Note that if you haven't yet set the study to be time dependant, the F(time) - table option will not be available.
All this is based on Solidworks/FloWorks 2008. Exact method may vary in future versions.
No that helps alot, I was trying the f(x) command to simulate the initial conditions inside the airflow, but never could get the correct mach number and pressure for the B/C with respect to time.
