Lines on drawings not highlighting
BodyBagger
459
Hello all,
All of a sudden when adding dimensions on drawings the lines of the part I am dimensioning do not highlight when I hover over them with the cursor and therefor make it very difficult to select them. Is there a setting somewhere to contol this?
BB,
I suspect you may have a different view set to "Lock View Focus". If so then all you would have to do is unlock that view.
- - -Updraft
Normally that setting is "Dynamic highlight from graphics view" under Tools->Options, system options tab, display/selection category.
-handleman, CSWP (The new, easy test)
Importing .iges files has a tendency to deselect the "Dynamic highlight from graphics view" setting. Credit to handleman for that tip.
Joe
SW Office 2008 SP5.0
P4 3.0Ghz 3GB
ATI FireGL X1
