I am trying to simulate bending of a composite.
My compression strengths and tension strengths are different in all directions.
My question is: when I start applying the displacement (or load) during experiment, the contact point is under compression and at this point, my material behaves differently compared to tension region (down side of the composite) due to different stress-strain behavior under tension and compression.
As a result, I assume that my neutral axis is displaced. I am wondering what is the best way to simulate this? What should I take care of?
I would really appreciate any help.
Best Regards,
Sartor
Best Regards,
Sartor
