How to use cylindrical coordinates in ProMechanica?
mapledr
3
My FEA is a rotary part under torq loading and bearing constrain. The cylindrical coordinates will facilitate the loading and constrain. Anybody know how to set up a cylindrical coordinates to convert cartesian to cylindrical. Thanks in advance.
Are you using Mechanica in integrated mode or not ?
if integrated mode, just create a new CSYS from within mechanica as you use to create one within Pro/E, BTW, CSYS might be created on the fly when creating your BCs. Current CSYS turns into green...
In standalone mode 3 points might be created as soon 1-2 vector is orthogonal to 1-3 : simple as that
Cheers
Ph.V
Yes I am using an integrated ProE20 and ProM. Could you explain the detail procedures to creat a cylindrical coordinates in either ProE or ProM? I tried without success.
Thanks again.
