RISA Mass Node changes
WBUW
63
I modeled a 5x5 tubular column as plates. I'd like to change it to a 6x6. Is there a fast way to do this without having to change each and every node? Theres alot of nodes...
There is a "Scale" feature that will allow you to scale up the size of your struction in 1, 2 or all 3 directions.
Just go to the Main Menu Toolbar and select Modify - Scale...
