axisymmetric analysis with asymetric loads
groveri
Aerospace
I'm trying to do a simple 1 element static linear asymmetric load analysis of an axisymmetric PLANE2D element model (COSMOS/M 2008) which requires us of the A_ASYM command. The COSMOS documentation is pretty weak on the subject. I apparently get a successful run, but the results are null. My .ses file is attached. Has anyone ever used this option successfully?
I may be solving my own problem, I found a good description in the COSMOSM BAsic System Documentation that might show me the way. Would still appreciate any samples.
