PeterStock
- Dec 18, 2006
- 569
I have a question that is derived from a drawing I recently checked. There were two values in the title block for angles, one of +/-2 degrees if the angle was stated as a whole number and one of +/- .5 degrees if the angle showed a decimal. My question is which applies in the case of an implied 90 degree angle?
My thought is that if I was making the part I would assume +/- .5 degress, but if I was inspecting the part, I would use the +/- 2 degrees as my accept/fail criteria. I am thinking that the 2 degrees would be what it would be rulled as in court (if it came to that).
What do you think?
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
What do you think?
Peter Stockhausen
