chrisj946
- Dec 6, 2010
- 1
I am designing a beam and plate shoring system. I have the project modeled right now. The problem I have is defining the load that is applied to the plate and then transferred to the members. The top 0-25% of the load is triangular 25% -75% is rectangular, the bottom 25% is triangular. How I define the plate load in this manner. Or should I apply it s a aream member load and do it in sections. If so, ho can I change the distribution to triangular for certain sections? I am using Risa3d 5.5.
thanks
thanks
