Flanges on a pyramidal sheet-metal surface model
cjjatpuresilica
65
Recently rollupswx has been kindly helping me resolve a pyramidal sheet-metal model.
I have a residual problem that has been dogging me for some while; namely the flanges and in particular the bottom flanges on the attached model.
I cannot apply fillets to the intersections between the flanges and the main body without introducing rips.
I accept that I could thicken the surface model without the bottom flange surfaces and then add standard flanges under the sheet-metal option.
However, regardless of how wide I set the mitering gap under auto corner mitering, the end result always diminishes the very bottom of what I describe as the hip beams or corners.
It is imperative I retain the hips/corner beams in their entirety, thus my attempt via the rectangular cut-outs through the corners of the bottom flange surfaces in the attached model; which hopefully will leave the hips/corner beams in tact after filleting the intersection between the flanges and the main body.
So how do I introduce rips at the end of each of the bottom flanges to allow a radius to be formed?
Do I just form the rips by simple extrusions; or is there an automatic simpler means?
Or am I going about this in entirely the wrong manner?
Thank you for your kind help.
cjj@puresilica
