Flange Stud Table
Guest
Looking for flange stud table ANSI 150-600 up to 8"
I assume you need flange bolt lengths and diameters?
This information is found in any of the pipe fitters' handbooks published by companies like Grinnell or Tube Turns. YOu could probably find it on the web also if you do a Google search. Maybe Daniels has it on their website. Thanks!
Pete
