Merging two separate RISA models into one
ATSE
Is it possible to merge to distinct RISA 3D models into one.
I have two somewhat complex models, but for this discussion, let's say I have a 20' tall flag pole on top of a 2 story building, where the top of roof beam = 30'
Both models have identically defined load cases, with concentrated and distributed loads for each model.
The flag pole base is at 0,0,30'.
Can I merge the flag pole file with the 2 story building file?
Trying to avoid re-creating the complex loading.
Go to the main menu toolbar and select File - Append. This will allow you to combine an existing RISA-3D model with the one you already have open.
