Problems with Unstable Model 1
jharr11
Automotive
May 3, 2011
7
Hey guys,
For the past couple of weeks I have been beating my head against a wall trying to do a static simulation study on a race car chassis part file. The error I keep getting is the "unstable model, restraints may not be adequate" one. I feel like I have tried everything to fix this but to no avail. I have checked the "use soft spring to stabilize model" box, and that didn't help. I have added over 400 bonded contact sets between all the tubes. I have tried using fixed geometry fixtures all over the place and that hasn't helped either. I really don't know what else to do to try to find where the problem is. Attached is a picture of the meshed model. ANY help would be greatly appreciated. I would be happy to provide more info if needed.
Thanks in advance,
-John
Life would be so much easier if you used beam elements. Then find your critical connections and make sub models. I can't imagine how many unnecessary dof you have in this model. And you still won't get "real" stresses near the joints with such a coarse mesh.
Step back and ask what you are trying to find out.
TOP
CSWP, BSSE
"Node news is good news."
The entire model is beam elements. The mesh is not fine because I am trying to at least get the thing to run first before I even think about optimizing it.
Also, submodels won't help me because I'm concerned with displacement in the model as a whole. As far as I'm concerned there are no unnecessary DOFs. I'm not interested in stresses. This structure will likely never see any stresses near it's limit.
Thanks anyway for your help, but I've figured it out. Turns out I had not properly defined the contact between the small solids in the model and the beam elements. [thumbsup]
I went through the model excluding features from the analysis one by one until I came upon a beam with an adjacent solid feature.
