Memory Status Bar
Jaydez
6
Does anybody know what happened to the memory status bar that used to be displayed in the bottom-right corner in previous versions of Inventor? It was helpful to know how much memory I had left while working on large assemblies. I've been crashing lately and I suspect it's because I'm running out of memory...
It is not included in the 64 bit version of Inventor anymore, however if you browse to your BIN folder in the Inventor program files you can find a little program called memprobe.exe that will do the same.
