Inventor 2012 suite 1
cadmate
84
Is it possible to install Autodesk 2012 suite onto the same machine that already has Inventor 2011 Pro? I need to keep 2011 running because of exisiting customers that have not upgraded.
Any advice appreciated
yes I always have 2 versions loaded like that. Just remember that anything you do on 2012 will not open in 2011. (Inv is not backward compatible) You can save as step/iges though and open in a previous release.
