Selecting internal surfaces
fruton
56
Hello all I am new to Autodesk inventor 12
This is a very simple question, but would be useful to know how to select hidden surfaces which are covered by other surfaces. It's easy when you now how :) thanks.
Part environment?
Assembly environment?
Can you use the Select Other tool, Selection Filters, or temp section?
Thanks for your reponse rollupswx, I am refering to both the part and assembly enviroment. The only way I have been able to achieve this so far is to hover my mouse over the area of interest and then a drop down menu appears with the options, however, it is still difficult to distingish between faces, especially if one face is in contact with another face.
Is this what you mean by select other tool.
Thanks.
