WEIGHT ESTIMATE FOR HEAT EXCHANGER 1
babashitu
5
could any one help with a guide or procedure to estimate the weight of shell and tube heat exchanger, air-cooled heat exchanger if the only information provided is the duty of these heat exchangers. I have the duty and weight of similar equipment on a particular plant.
Use the ratio of duty:rate of one of your known Fin-Fan Hx's. Pick one as close as possible to the unknown one.
And next time, you probably want to post Hx questions in the "Boiler and Pressure Vessel" forum. This one is API tanks.
