1
- #1
MudBugg
Petroleum
- Nov 15, 2011
- 2
I am working on a small project for my company who uses various Valves in a production line. What are some of the common failures for valves such as Gate Valves, Ball Valves, Check Valves, etc? I will be compiling a 'cause code' sheet to fit in with the Root Cause Analysis project, so breaking down failures to specific areas of the valve would be appreciated! I'm going to start off with the little pieces I have gathered so far, please feel free to let me know if I am on track.
Body > Corrosion
Fatigue
Stem > Corrosion
Fatigue > High Torque
Seals >
Body > Corrosion
Fatigue
Stem > Corrosion
Seals >
