RISAFoundation - moment on a pile
gb156
33
Does RISAFoundation calculate the moment on a pile due to lateral load? I see shear, compression and tension in the pile design check, but no moment check.
No, it does not. The program is not trying to design the pile itself. It's assumed that the allowable loads (shear, tension, compression) come from some other calculation or soils report.
For piles, the program's main focus is on desiging the pile cap, and analyzing how much load will make it's way into each pile.
Thank you for your quick response!
