paulofficer
- Sep 9, 2002
- 1
I am using Staad Pro to carry out a FE design of an irregular floor slab.
The problem is this: From the output, I can get Mx, My, and Mxy in the element local axes, but only Mx and My in Global axes. Mxy is not accounted for in this global moment (i.e. Wood-Armer) and is not given to allow me to calculate the design moment myself.
I think it is possible to convert Mx and My from local to global coords by multiplying by the Cosine of the angle. This is based on the the fact that if a direction of a force can be modified by cos(angle) then a moment can be converted in the same way as it is just a force at an eccentricity. For Mxy though, I'm not sure if this argument still holds true.
Can anyone shed some light on this?
Thanks, Paul
Thanks, Paul
