Can anyone recommend a typical detail for attaching a W beam to a wood column?
Also, when inserting a steel drop beam below existing wood joists (e.g. as in replacing an existing stud bearing wall), is it possible to brace the compression flange of the steel beam with the wood joists? If so, what is the best way to connect the joists to the beam... wood nailer w/ toenails, clip angle with thru-bolt, some sort of Simpson clip, etc.?
