PujanG
- Nov 1, 2011
- 22
I wanted to define material in SAP2000. But came across some data that i hadn't used during manual design.
What are these & where can i find the values for Fe 415?
Minimum yield strength
Minimum tensile strength
Effective yield strength
Effective tensile strength
2nd problem:
I'm designing a slab. When i went to define area element it had many options such as thick shell, thin shell, thick plate, thin plate,membrane..
how do i know which structural element is best modeled as Shell or Plate?
2nd problem:
