SLC 5/05 Ethernet IP Communications
Golfman79
1
I have a new to me piece of equipment with a AB SLC 5/05 PLC that is already running an existing program. I do not have a copy of the PLC program, and have no idea what the ip address is. Can anyone point me in the right direction so that I can communicate and upload the existing program?
you should be able to pull the program and read the IP address via the serial port
you should also be able to 'discover' the device on RSlinx with an ethernet IP driver loaded.
