tm7128
- Mar 29, 2012
- 4
What should be the correct way to ground a PLC Panel? Is it necessary to instal an isolation transformer for the grounding of the PLC panel?
Or can we bring a ground conductor (isolated ground) directly from the 120V distribution Panel and connect it to the ground bus of the PLC panle; and then bring one more ground conductor (isolated ground) directly from the ground bus of the 120V distribution panel and connect it to the body of the PLC panel?
