sigtro
- Aug 1, 2012
- 4
Hi.
I'm working on contact forces between a ship propeller and propeller-hub interface. The shear forces is taken up by a free link between the two faces. Axial through bolts.
Simplified draft:
Bolt holes in section A, link in section B.
I use a surface contact mesh between the contacting faces, rbe3 and beam elements as bolts. Fixed the rotation and on the link to eliminate rbm.
When i use sestatic 101 with iterative solver i don't get a result file, and a error message in the solution log file saying.
******PCGLSS Error******
Status:11
Version:7.0
PCGLSS0163
PCGLSS0163CGLSS aborted by calling program
Source File
D:\Scratch\qasimtst\pb7\nastran1\indep\casi\pcglss\cwrappers_std.c
Line:1682
20:45:18 NSEXIT: EXIT(0)
20:45:18 Analysis complete 0
Any idea of finding more info on the error? Have no D:, so that's not a normal dir.
Simplified draft:
Status:11
Version:7.0
PCGLSS0163
Source File
Line:1682
