How to implement and run a subroutine (on UNIX/LINUX with MSC MARC & MENTAT)?
bort2bort
AT
Hi!
I want to include a subroutine [tt]uedinc.f[/tt] when running the input file [tt]model1_job1.dat[/tt].
As described in the MARC manual Volume C I entered in the terminal window within the current working directory:
[tt]marc -jid model2_job1 -user uedinc -save yes[/tt]
This should create an executable file within the current directory with the ending *.marc[tt][/tt], but I can't find this file.
Afterwards I entered:
[tt]marc -jid model2_job1 -prog uedinc [/tt]
in order to execute the (non-existing-)executable file [tt]uedinc.marc[/tt]. The job finishes with 3004 (OK), but no error message, neither an entry in an outputted file anywhere.
(But I can't find the *.log-file.)
The job [tt]model2_job1.dat[/tt] exits with exit code 3004 (that is OK).
But my user subroutine uedinc[tt][/tt] doesn't seem to be opened. There is no output in the *.out[tt][/tt]-file, nor in any other file.
Compiler / Reinstallation of Marc
Compiling the file manually with the command:
[tt]f77 uedinc.f[/tt]
works, so I get some error messages in the terminal.
Reinstallation of Marc didn't help too.
Can anyone explain to me step by step how to run a job with a user-subroutine in marc and what should be seen/created after each command?
Thanks, Steeve
