Bearing plates
Ganotec
5
Is it common practice to leave and extra portion of annular ring out of the tank periphery, or would it be beneficial to use a bearing plate in the case were I would need 8 inches of extra annular ring in order to compensate for a low soil bearing pressure?
I have also been told that bearing plates could accelerate the corrosion of the annular ring.
What option is the best for me?
Thanks in advance,
