newbuilder
- Jul 1, 1999
- 73
I have come across a situation where an engineer has undertaken a detailed analysis of the bending moments induced in the columns of a tall building caused by shrinkage. I have been able to find a small reference on this kind of effect in one text but not much.
My question is this: in a tall reinforced concrete building, the floors would be expected to shrink at roughly the same rate and time. Would any forces theoretically induced in one subframe by the restraint (fixity) between it and the floors above and below be of serious consideration or would they cancel?
The building in question comprises a post tensioned floor scheme; however, would this make a difference on the quantum frame forces. Understandably the shrinkage affects the PT losses but i think this is a separate issue.
nb
nb
