ASME reinforcement welding
fjodor
20
I'm searching ASME manual, but I just remmbered I registered here as well so maybe someone could save me reading hours.
I need rule for welding reinforcement part of pipe to shell pipe. Trouble is if I use standard a=0,7 tmin. I don't have enough pipe thickness, since "a" is calculated arround 12,2 so normally I would use a13, but there is no room for that ofcourse. Is there a=0,5timn allowed (cant't remember)? THX.
I assume Design Code is ASME Section VIII Division 1. I also assume you are asking about the fillet weld size requirements whether the joint between pipe and shell is full penetration or not. The minimum weld size requirements are given in UW-16. These weld sizes may be required to increase if required to meet UW-15 and UG-37.
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
Thx for quick answer. Yes, I wasn't clear enough in openin post, asme VIII div. 1. fillet.
I'll go check UW-16 asap.
