I've got a large pipe column supporting a sign structure that was hit by a large vehicle (Semi Tractor) and damaged. Pipe is 36" dia x 0.375" wall thickness. Photos linked below.
The column is cantilevered from a block foundation using lateral bearing to resist lateral loads. Axial loads are minimal relative to bending. My first instinct was to provide a wrap/doubler plate over the damaged area. The 'dent' is pretty well aligned with the sign face so that it's in the area of maximum bending stress. I'm in the midst of figuring out how to get the stresses transferred into and back out of the plate. But before I get too deep with that, I was wondering if any of you might have any bright ideas for repair that I'm missing. Or issues I'm not considering with this approach.
I'm thinking that I'll need to extend the wrap above and below the damaged area enough that I can provide a series of plug/slot welds to achieve the required stress transfer. I'm not really comfortable with a big fillet weld across the top and bottom and brief numbers show the sizing wouldn't be practical anyway.
One of my concerns is that the section isn't simply dented, but overly deformed where a nicely rolled plate wouldn't fit over the dented area. I wonder if a series of adjacent channels spanning the dent would be more practical. At least with those the flanges could be trimmed to fit over any deformations...and then I could use all fillet welds. Hmmmm...
Foundation damage is going to require the removal and replacement of some concrete below grade.
Thoughts are appreciated.
