Hi all,
I am tryng to get that parameter ( //xydxdy (where // is the integral symbol) as defined here for a plane section in autocad.
The section is drawn as a region, but I get a zero with the command fisprop. Furthermore I do not think that product of inertia is what I search for since:
Autocad help
"Product of inertia
Property used to determine the forces causing the motion of an object. It is always calculated with respect to two orthogonal planes. The formula for product of inertia for the YZ plane and XZ plane is
product_of_inertiaYZ,XZ = mass * distcentroid_to_YZ * distcentroid_to_XZ
This XY value is expressed in mass units times the length squared."
Someway to calculate the product moment area???
Autocad help
"Product of inertia
