Short answer, YES. If you don't understand why, there are several older posts here that you can search for that will help you to understand. Corrosion is not the problem, its more of a fundumental fluid dynamics problem. You cant have water hammer until something in the system changes so thats not it either because you can regulate the effects of transients by design. Cavatation is the problem as eluded to by flame.
Do you have a system that is flowing like this? Is it in design or existing? Please tell us more.....
BobPE
