sammer003
Petroleum
- Mar 1, 2013
- 2
Hi guys,
I have a nitrided, hardened, steel puck that sits and is held in a milled steel (4145 HTSR) pocket. The pocket of the body is gradually showing an imprint of the bottom of the puck, due to vibration and contact on the top of the puck. So basically, the contact is on the top of the puck, and the bottom of the puck (the puck bottom has a couple of grooves) is leaving an imprint in the pocket. This also results in the puck not being to size anymore, since it now sits about .030" lower (because of the imprint) after time, even .080", and that would be the maximum it would be. After that, the pocket is damaged, and is discarded.
We want to increase the life of the pocket without changing the puck. Material would be the best.
1. Would a higher material charpy impact test help? Currently we show about 55-60 ft-lbs charpy impact test.
2. We thought of using a sacrificaial 'disc' underneath, about .020-.030 thick. Haven't tried it yet.
3. We must have the puck nitrided and hardened, to resist the constant pounding on the top of the puck. Otherwise, it doesn't last.
4. Would gas nitriding the pockets help?
5. Would hardening the pockets help? Ideas?
Thanks.
Thanks.
