Wrapping solid to the surface 1
PrintScaffold
RU
Greetings all!
The task is to wrap the solid body to the reference surface. Shape of the wrapped solid should be correct, e.g. all perimeters of the edges must not change. What is the correct tool for the task?
I attached a part file to this message.
on part level you can extact ( the name of the button) all bodyfaces.
My interest is the workflow behind. It is because it must not to be done in Nx like in your other cat system.
I have seen this mess with diamler they not really turn the cat system they turn Nx to V5.
I understood absolutely nothing of your reply.
on partlevel down in the single part you can
Menu Insert -> asotiative copy -> extract geometry
in the dialog extract geometry type choose -> Face
face option -> body face ... select body...
detailed enough?
regards
You have clearly not understood what I was asking. Look up the meaning of the word 'wrap'.
excuse me I had the wrong download, mess with filenames.
one way is to project the boundary curves on the other geometry
Projection won't work in many cases, it will distort the edges.
Does the file attached below meet your requirements?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=d017af05-0734-4521-a9e9-68cc9bb32100&file=Wrap-JRB-1.prt
Thank you, John! In this case, it does.
But what if the surface has the shape like in the file attached to this post?
I came up with some solution, but I'd love to see what you can do in this case. It will likely be a better way.
 http://files.engineering.com/getfile.aspx?folder=1d489968-ab7a-4747-bedd-cd8d00562f34&file=Wrap_2.prt
That took a little more effort (had to create an additional sketch) but look at the attached model anyway.
Note that with the next version of NX (the one after NX 8.5) we've made a couple of enhancements which will allow you to create this model with 1 Sketch, 1 Surface and 1 Wrap operation. Basically you would have created a single-faced Ruled-Surface using the new 'Developable' option and then created a single Sketch tangent to the face of the surface and then create a single wrapped-curve feature as you will now be able to Wrap onto a 'Developable' surface as well as a Cone and Cylinder (after all, that's one of the characteristics of being 'developable').
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=ee68fe83-9539-49f0-b9ec-8a4511f49b09&file=Wrap_2-JRB-1.prt
Thanks for the tip! I attached a file with my own solution. I went via sheet metal bend/rebend route.
Exciting news about additions to the NX! Wrapping of thin parts is a department where NX is currently not very robust. Improvements there are very welcome. Can't wait!
 http://files.engineering.com/getfile.aspx?folder=87580335-9015-414e-8130-be1cbcf24058&file=Wrap_Bend_Rebend.prt
Remember, the real enhancement is the ability to define a mathematically 'developable' surface, which ironically UG supported 30+ years ago, but which got lost when the freeform surface modeling architecture was moved from being based on 'parametric cubics' (a type of Coons patch) to Bezier patches and NURB's. Of course we didn't have any sort of wrap/unwarp functionality back then so it was more of a mathematical 'check in the box' than actually having integral downstream support, like we're going to be doing with the next release of NX, starting with at least Wrap/Unwrap.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
