on coil off coil temperature
girij
1
hi all i am new to HVAC . Could any one explain to me, how to find out on / off coil temperature.
for example : Outdoor temp 45 deg and 90 RH
Room temp 24 deg and 50 RH
MY AIRFLOW IS 16250 CMH
SENSIBLE LOAD 54.85 KW
Do i need any other details apart from these.
GIRI
You need to read forum policies which begin as follows:
>>These fora should not be used to bypass your own in-depth research on the issues that affect you, nor is it intended to be a substitute for appropriate professional assistance within your field or geographical region.
I second willard3. Please research first, provide sufficient information what you have and what you need. It seems you (or someone else) must have done some calculations based on your numbers provided.
but here some information:
- what do you actually want to do? Cool 100%OA, heat, recirculate? To me this is unclear.
- what do you actually need, the coil size, or discharge air temp?
This is school question. No, you need at least one more piece of information.
