Terminology question - threaded boss
illini8181
This is a terminology question. See attached. This is a threaded piece with a rounded upper surface which can be threaded in and out of the plate shown. The plate is the base of a larger structure. There are four of these threaded pieces, which allow the angle of the base to be slightly adjustable. What would you call the threaded piece? One of my coworkers called it a "threaded boss", which was terminology I am not familiar with. Any ideas? I know this is a pretty trivial question, but humor me :)
Threaded stud
Levelling screw
Set screw
Definitely not "Threaded boss"
The threaded male element I agree with those above. If you needed to weld / fix / glue on the female part of this, say onto a thinner sheet, that is what I would call a threaded boss.
Looks like a set screw used as a leveling screw
Posting guidelines faq731-376 (probably not aimed specifically at you)
What is Engineering anyway: faq1088-1484
A "boss" is a protruding lumpy feature that is part of a casting (or left by machining away surrounding material in a billet").
The boss would be milled flat (optional, I guess) and then drilled and tapped.
This is an example showing typical "threaded bosses" in my opinion.
There are 8 "threaded bosses" in this picture. Each one is an inch or so directly below an assembled valve/spring
Then a threaded component (rocker stud in this case) is wound into the "thraded boss"
A threaded boss would be the levelling screw's female counterpart. i.e. the equivalent of a nut.
If your boss is threaded, that’s got be an awful place to work and I’d look for a new place to work. And, if your male part is threaded as LittleInch suggests, you’re talkin bout the wrong kinda screwin.
