nissan4ever
- Jul 2, 2011
- 10
I'm installing about 200 feet of 6" & 8" FBE coated steel pipe in a private unpaved lot. The design calls for a typical backfill for unpaved areas with native soil or sand per our company standards if native soil is unsuitable. Well the contractor discovered that the native soil was unsuitable for backfill and asked if he could backfill the 7-8 ft deep trench with wet sand slurry/ zero sack. According to the contractor, the slurry will flow alot better and will cover the pipe better compared to sand. Also, the issue with sand is shoring concerns in the future. Zero sack is basically just water and sand right? I asked some of the folks in the office and they were concerned about corrosion. Also they were concerned about the possibility of a sink hole without at least a 1 foot of sand on top of the pipe. The few that said no to zero sack had a hunch that the contractor was just trying to get out of labor intensive work of filling sand and compacting.
Since I'm still relatively new to the oil& gas industry, I really just don't know enough about the different types of backfills other than native soil and sand. From my research, there are several types of backfills that we use such as zero sack, 1 sack (contains cement), 2 sack, A & B (aggregate base), and popcorn. Can anyone be so kind as to explain these types of backfill, such as pros and cons or possibily direct me to a good resource. Thank You
