FastenerDude
Industrial
- Jan 3, 2013
- 17
Good Afternoon,
I have attached a picture for reference. We supply ASTM A193-B7 studs that are Zinc Yellow plated to a customer who uses them to build a compressor. The studs are corroding quicker than expected. The flanges that these studs bolt up, are made of stainless steel so I suspect that galvanic corrosion is taking place. Would this be correct? The unit is located in-doors so it is away from outside elements. I asked my customer how long the studs have been in service and he guessed a couple of years, but if the unit is in-doors, corrosion on a plated stud should not happen this fast. We have B7, Zinc Plated studs that sit on our shelves for years that don't show any corrosion. Should I try to convince my customer to move to stainless steel studs? Any insight would be greatly appreciated!
Greg
System 22, Inc.
Greg
System 22, Inc.
