abehong
- Dec 3, 2012
- 22
I have been using ASME section III nuclear flange calculation for flange joint checking for one process piping design( design code ASME B31.#). Now someone is questioning whether or not ASME III nuclear flange calculation is accetpable for oil and gas applications . The piping sysem is not a nuclear class 2 system. Personally, I do not think the condition for using ASME section III nuclear flange calculation is to design piping system as per Nuclear code. The only condition is to use high strength bolting material and have proper installation procedure in place. Not sure if my understanding is correct or not. Is my understanding correct or not ?
