bookowski
- Aug 29, 2010
- 978
What is the typical method/detail for lintel for a shallow brick arch over a window. The arch has a peak of about 1.5" relative to the bearing ends, this is over a width of about 3ft.
I was thinking that an arched angle could be made from plate, with it flattening out at the ends for the bearing - is that the typical solution? Or do you use a straight angle and notch the brick (it's a soldier course) to make up that overhang?
