Continua
- Feb 12, 2013
- 1
I'm new to this forum, and I apologize in advance if this question has already been answered. I'm designing a 36-inch ductile iron gravity sewer line with several aerial crossings in the range of 20 to 60 ft each. These crossings pass over small waterways and we have a nationwide 404 permit to install.
For the longer crossings, we plan to use steel pipe to avoid the need for intermediate supports. Most crossing details I've seen show a steel casing pipe and internal carrier pipe configuration. Is there any reason we can't just make a single steel pipe crossing without a casing? In other words, the pipeline would transition from ductile to steel at each end of the crossing.
