RareBugTX
- Aug 31, 2004
- 214
Hello all:
Working on a project where we are relocating an entire floor 18" above the existing level (one story bldg with basement. Basement to have a higher ceil) Previous system was wood frame on steel beams. Now we will have noncomposite concrete/Steel deck supported on new steel beams and columns, footings. Max span 12.5' or less.
Question is, at the wall the deck support is been proposed a steel channel (6") as a ledge anchor bolted to exist 8" brick wall with ABs spaced per calc. Now whats the controlling factor? In my view is just ABs pullout from wall. Bearing and shear on bolt dont think is an issue (thinking 5/8" ABs) Anybody done any check on bottom of channel flange? Bending? Or anything else? I see it as simply supported on such bottom flange and spot welded deck to web. Any feedback, thoughts, ideas or sample calc resources would be appreciated.
RateBugRA
RateBugRA
