Neutralizing Anhydrous Aluminium Chloride
lesianatalia
Chemical
Nov 6, 2002
1
I have some anhydrous aluminium chloride (>99%) on site that I need to dispose of. The problem is that anhydrous aluminium chloride is extremely water reactive - giving off hydrogen chloride fumes on contact with water.
My facilities to deal with these fumes are limited, so I thought the best way to dispose of it would be to use a neutralizing agent like caustic soda first. Not quite sure if this is the most safe way.
Any suggestions?
Have you already dealt with this problem?
As you suggested, neutralize with NaOH (use a small excess) in a large volume of continuously stirred water. Rxn. is
AlCl3 + 3 NaOH(aq) = 3 NaCl(aq) + Al(OH)3(aq)
As FW AlCl3 is 133.35 & FW of NaOH is 40, I would an equal amount of NaOH predissolved in water & cooled [actually, I use twice as much 50 wt% NaOH solution, but still need to cool]. Suggest using at least 10 gallons of water+NaOH per pound of AlCl3 in order to absorb heat; that way can get rid of 50 lbs in a 500 gallon mixer.
Also, I would try to sprinkle the AlCl3 over the surface to avoid possible explosive boiling. If you have a large quantity, maybe put some fibergrate over the tank & then use a shovel to toss the AlCl3 over the grating. Of course, wear PPE.
If you have already neutralized, kindly post the method used & observations.
Ken
