NX9 Quick acess Toolbar
UserCFAO
44
I have a problem when i try to add Quick acess Toolbar
1 Command finder
2 "New"
3 "Add Quick acess Toolbar"
it's Ok
But when i click Application : ex "Modeling"
the Command "New" in Quick acess Toolbar disappear
thanks for the help
The customization is Application Dependent, so you have to add the button in Gateway (as you did I suppose), Modeling, drafting...
Didier Psaltopoulos
Hi
I found a WA or maybe it is a designed
We need to use Tools Customize
download.aspx
Didier Psaltopoulos
Hi guys,
You don't need to use command finder or customise to set up the QAT.
Just press the symbol at the right hand end of the QAT (looks like a down arrow with a line above it), and in there is the pre-defined list of options for the QAT which includes new and open). All changes made this way have worked fine for me.
NX 7.5 with TC 8.3
I've just tested using command finder for a command that isn't already in the pre-defined QAT list (I used extrude).
That stayed on the QAT after switching application to drafting and then back to modelling.
NX 7.5 with TC 8.3
I suspect the issue is that you can't have more than one copy of the same item on at least the Quick Access Bar and therefore since the the 'File New' and 'File Open' items are technically already assigned to the QA Bar, just not activated, when you attempt to add one of these manually, at least via the MB3 non-customize route, they are eventually removed by the system.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
hi,
thanks guys , it works for me with the old method [thumbsup2]
