drn
- Nov 12, 2002
- 2
I need some sugestions on possible causes for the following:
I have a fan/water cooling tower in Atlantic City NJ constructed of 304 stainless steel. The cooling tower seems to either be pitting or it looks like an iron colored overspray on the exterior of the tower. Along with this is a high concentration of brown iron colored residue or corrosion near the cold water basin. I know stainless usually will change color and brown out but this is more like spots and some areas of concentration.
The water quality is good. No excessive iron content and ph, chlorides etc are ok. (at least at the time of smaple taken) I suspect they are batch feeding something once per month. (Sorry I do not remimber the name, but I know it was not chlorine)
Any thoughts? I have many stainless steel towers in this area both in 304 and 316 sst and have not had a problem.
I have pictures if you would like me to e-mail them to you.
FYI
Just background on me so you can tailor your responses to my level somewhat. I am not a chem/metal eng. My background is in HVAC systems.
Dave
FYI
Dave
